Community Member
CCM Traces error
Hi Everybody,
We have an application called Iagent, it works as Cisco CAD for Call Center. Sometimes agents went logged off from the application. and when I check the CCM Traces I found the following errors.
ext. 5152
MAC: SEP002155D60237
time of getting logged off: 12:02
I am not sure what these errors mean. attached the traces.
12:00:59.462 |RouteListControl::idle_CcSetupReq - RouteList(CVP_RL), numberSetup=0 numberMember=1 vmEnabled=0|3,200,17,1.830623^10.62.101.103^SEP002155D60237
12:00:59.462 |ViprUtils::isViprAllowed Get device row from ccmdb returned false for  PKID=[]|3,200,17,1.830623^10.62.101.103^SEP002155D60237
12:00:59.464 |//SIP/SIPCdpc(2,68,784632)/ci=42320628/ccbId=1555405/scbId=0/addTransparencyInfo: Transparency info is NULL.  Not attaching anything.
12:00:59.513 |ConnectionManager - wait_AuDisconnectRequest ERROR:NO ENTRY FOUND IN TABLE,CI(42320627,0),dcType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)|2,100,50,1.74508647^10.62.100.194^SEP002155D60237
12:00:59.513 |MatrixControl:updatePartyMediaCoordinatorNodeId: party1 videoCapable=0, party 2 videocapable=0|2,100,50,1.74508647^10.62.100.194^SEP002155D60237
12:00:59.514 |RSVPSessionMgr::wait_PolicyAndRSVPUnassociateReq, cannot find RSVPSession, ci= 42320627 |
Regards.
Mohamed Helmy
Regards, Mohamed Helmy
Everyone's tags (1)
Hi Mohamed,Both of the above
Hi Mohamed,
Both of the above trace snippets are not related to agent logout issue. You need to check the traces for the exact time stamp when the issue is reported, detailed CTI manager traces would also be needed.
Manish
Community Member
Thanks Manish for your
Thanks Manish for your reply
attached the CTI manager traces
Hi Mohamed,I did not find the
Hi Mohamed,
I did not find the time stamp ( 12:02 ) in the CTI traces that you uploaded.
For such issues you should gather all of the following:
time stamp
mac addr
detailed ccm traces from all servers
detailed cti manager traces from all servers
Manish
99
