CCM Tracking changes for Audit Purpose
I am using CCM 4.3.
Is there any way I can Track , who does what configuration change in the CCM , using CCMAdmin tool.
Re: CCM Tracking changes for Audit Purpose
no, at most MLA logs for to know who accessed, and that if you use MLA. if not then any change must be in the iis logs but they're not pretty or easy to understand
java
if this helps, please rate
java
www.cisco.com/go/pdi
thanks.
Can you please elaborate "MLA logs for to know who accessed, and that if you use MLA".
thanks
Multilevel Administration
simply like this, if you use CCMAdministrator to log you use MLA, if you use the server credential no MLA
java
java
160
