CCM upgrade 4.1(3) to 4.2(3) issues
I upgraded Pub and 2 Subs to new version of CCM. Certain things are not working right as it supposed to be.
Extension Mobility users when they logged into the phone, the extension is same that of the phone and user does not get his extension
DBhelper shows doublicate server name for Publisher and Sub2 as nothing has been changed on the hosts and lmhosts files or in the sql database
When we make call to mobile or national number, it adds extra 9. So, user sees two 99 instead of one 9 plus area code.
Tried to use extension mobilty, its says Busy pls try later.
Anybody as similar issues.
Cheers
1 REPLY
Green
Re: CCM upgrade 4.1(3) to 4.2(3) issues
Hi Shahid,
Hope you are fine, I would recommend you to open a TAC case so u get the support u deserve.
Dont forget to open 1 TAC case per issue.
116
