Community Member
CCM upgrade 4.1 to 4.3 question
Hi all
I have  a question the CCM 4.3 support windows 2000 or not ?
because I have a CCM 4.1 with OS windows 2000 and I want to upgrad it to CCM 4.3.
Thanks and kind regards.
Everyone's tags (4)
Community Member
Hi Bouchaib,
The CCM 4.3 work with Windows 2003, but, I believe that there is not more support Cisco for this version.
Wilson
You basically need to rebuild the server and then re-import the data for the W2K to W2K3 upgrade. And no, 4.3 is not supported on W2K. Review the online documentation for the upgrade procedure.
If you're going to do that much, you might as well go to a Linux appliance if you can.
It still has support
End-of-Sale and End-of-Life Announcement for the  Cisco Unified Communications Manager Version 4.3
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/vcallcon/ps556/end_of_life_notice_c51-612453.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
317
