CCM upgrade from 3.3(5) to 4.2(1) generates high CPU
Hi there,
recently I have upgraded a cluster of 9 CCM from 3.3(5)sr1a to 4.2(1)sr1b.
At the end of the migration we have seen high CPU util on some subscribers with ccm.exe process that crashed and hard instability of the environment. We have rolled back to 3.3(5).
Now are evaluating to repeat the upgrade passing to CCM ver. 4.2(3), unfortunately the italian locale is not available on CCO, even if it seems that the 4.2(1) is good as well.
Does anyone has seen similar problems?
Thanks for the reply
Paolo Marovino
Anonymous
N/A
Re: CCM upgrade from 3.3(5) to 4.2(1) generates high CPU
Stop the Media Streaming App service and change the startup settings to disabled or manual. Use the Serviceability Control Center tool to activate Media Streaming if required.Refer URL for the bug CSCdx40494
http://cisco.com/en/US/products/sw/voicesw/ps556/prod_release_note09186a00800a9396.html
Green
Ciao Paolo,
You may upload first drwtsn logs to see crash info.
Be aware that CCM 4.X consumes more resources than 3.X.
Check the following link please:
Physical Memory Recommendations for Cisco CallManager Vers. 4.0
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_bulletin0900aecd80284099.html
Cisco CallManager Service Crash
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d2577.shtml
137
