CCM Upgrade from 4.0(1) to 4.2(3) SQL Server requirements
Hi all,
I'm planning a CCM upgrade from 4.0(1) to 4.2(3). I've had a look at the CCM Compatibility Matrix and it states that the 4.2(x) versions of CCM have "No minimum SQL 2K requirement". This surprises me a bit. Does version 4.2(x) not use SQL Server 2000 the same way as previous versions? How can there not be a minimum requirement?
I am currently running SQL 2000 SP3 on my CCM 4.0(1) servers and am debating wether or not I should apply SQL 2000 SP4 (which is available on cisco's site)if only for the security fixes it should include. If I do I would only do it after the 4.2(3) upgrade in complete. Good move or bad move?
Thanks! - Peter
1 REPLY
Re: CCM Upgrade from 4.0(1) to 4.2(3) SQL Server requirements
I got my own question answered by the TAC for anyone interested here is their response...
"I was discussing the service pack issue with some co-workers and when you install the operating system 2000.4.3a, the system install the SQL 2000 SP4 patch by itself. Because of this there will be no problem with that patch."
101
