CCM upgrade from 5.1.2 to 6.1
Hi All,
we are planning to upgrade our CCM 5.1.2 publ. and subscr. to SW version 6.1.
Has someone done it already? Any known issues during the ugrade?
I know so far from the upgrade doc. that it is an straight through upgrade, licence continues, and it take a long time to finisch.
Thanks a lot
1 REPLY
Re: CCM upgrade from 5.1.2 to 6.1
the license and DLUs continue but you need to get the feature license for the upgrade before doing this
after the upgrade if you don't have that license you won't be able to start the services.
the upgrade is pretty straightforward as you mention, once you get the files do the upgrade via the OS admin page and make sure to apply it to all servers before rebooting and changing the partitions
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
96
