CCM upgrade from 6.1 to 8.6
Dear All,
we  have CUCM System version: 6.1.2.1000-13 running on MCS7825I3-K9-CMB2 and we are planning to upgrade it to 8.6 , do i need to change my hardware or not ?
please advise.
2 ACCEPTED SOLUTIONS
Hi Muzzamil.
This link should help you
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Carlo
Please rate all helpful posts "The more you help the more you learn"
Yes, it is Supported, but note that Cisco Unified Communications Manager 5.0 and later require or recommend (depending on server model and software release) minimum memory and disk size as described in the table below. For Cisco Unified Communications Manager 8.0(3) and above, it is strongly recommended to upgrade to minimum 4GB RAM and 146GB disk drive; whether this is necessary for your deployment is design-dependent and depends on call volume, installed locales, dial plans, phone firmware loads, music files, etc. Use
http://www.cisco.com/go/swonly to get supported memory and disk part numbers. Supported, but note that Cisco Unified Communications Manager 5.0 and later require or recommend (depending on server model and software release) minimum memory and disk size as described in the table below. For Cisco Unified Communications Manager 8.0(3) and above, it is strongly recommended to upgrade to minimum 4GB RAM and 146GB disk drive; whether this is necessary for your deployment is design-dependent and depends on call volume, installed locales, dial plans, phone firmware loads, music files, etc. Use http://www.cisco.com/go/swonly to get supported memory and disk part numbers.
Please rate helpful posts.
GP.
Hi Muzzamil.
Carlo
GP.
Thank you guys for your support, i will try to do a trade in with Cisco if they will accept
Regards.
246
