CCM upgrade to 6.1.1
When I tried to upgrade existing v6 to new 6.1.1 locally with DVD drive. It gives following error
The requested command /usr/bin/sudo/usr/local/bin/base_scripts/upgrade_validate_file.shmethod=localsource_dir=file_name=UCSInstall_UCOS_6.1.1.2000-3.sgr.iso] didnot generate the appropiate results for file. The process result could not be determined.
any thoughts???
thanks
muhammad
Green
Re: CCM upgrade to 6.1.1
With SFTP same error?
Did not try with SFTP? Which software do you recommand?
thanks
Hall of Fame Super Red
Hi Muhammad,
The one that I have seen recommended the most on these forums is freeftp;
FreeFTP
http://freeftp.com/
Hope this helps!
Rob
Why did you not try to upgrade via the webpage of the CUCM6
I did it also and CM 6.1.1.2000-3 is currently running. It's easy to to do. If you don't want to use the CLI of CM6 . further I see UCSInstall_UCOS_6.1.1.2000-3.sgr.iso instead of UCSInstall_UCOS_6.1.1.2000-3.sgn.iso
hope this helps.
Fred
How can I upgrade via CLI
Br
Muhammad
Did you ever find a answer to this, I am getting the same error from the DVD.
154
