CCM Upgrade
I want to upgrade CCM 6.1.3 to CCM 7.1.3 but I don't know the exact part number for it. Does anybody know this? Is there any other thing needed for this upgrade. I need clarifications
Hall of Fame Super Silver
Re: CCM Upgrade
Assuming you have valid UCSS support contract you can do this via PUT tool www.cisco.com/go/upgrade and request the upgrade media there.
HTH,
Chris
Re: CCM Upgrade
As Chris stated if you have UCSS you order the upgrade through PUT at no additional cost.
However if your CUCM is not covered under UCSS then you'll have to pay for the upgrade.
The Part Numbers depends on the MCS server model you have. If you have 7835 for example the part nnumbr will be -
CM7.1-U-K9-7835= SW Upgrade to CM 7.1 - 7835
-> Sushil
Re: CCM Upgrade
If you are not able to order the upgrade through the PUT tool
<http://www.cisco.com/upgrade>
You can You can contact Customer Service through 1 of the following ways.
PHONE : 1-800-553-6387
Email : cs-support@cisco.com , subject line put in "Missing CD/DVD Request".
Customer service will need as much of the following information you can provide.
1. Reason for Request
2. SO#
3. SAS/SASU (or any other Software Contract #)
Vivek
998
