Community Member
CCM UserPage - Call Forwarding
If I am in a situation by which my PUB is down, are users still able to make changes to CallForwarding on their lines? My first inclination is that it is not possible as the SUB is a read-only database but I wonder if anyone knows definitively.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CCM UserPage - Call Forwarding
Hi Nicholas,
You are most correct here :) If the Pub is down or Replication between the Pub and Subs is broken no changes can be made to CFWD ALL. Here is a doc that speaks to this question;
This is a list of possible symptoms if the subscriber stops replicating from the publisher:
Changes that are made on the publisher are not reflected on phones that are registered with the subscriber.
Outbound calls fail on phones registered with the subscriber. As soon as you dial 9 you hear a re-order tone.
Call Forward All (CFwdALL) does not work.
IP phone displays Error Database.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
Hope this helps!
Rob
Hi Nicholas,
From this doc;
Hope this helps!
Rob
Gold
You have not mentioned the CM version, but I'd assume you have CM 5.x or below. With these versions, yes you cannot do a Call Fwd when the publisher is down. No changes to the DB can be made when the Publisher is down and multiple features are disabled and one being Call Fwd.
With Communications Manager 6.0, the Database Read/Write Behaviour has been changed.
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/cucm/rel_notes/6_0_1/601cmrn.html#wp116166
This being said, I'm not sure if this Feature has also been upgdated or not. But this for sure is on the RoadMap and the option to change Call Fwd settings when Publisher is down should be available soon.
122
