CCM version difference.
bhupendrab
HI All,
I would like to know the difference between all the versions of the CCM.
CCM 4.X is windows based and DB is SQL.
CUCM 5 and above are linux based and and informix the DB.
Would like to now the difference between CUCM versions 5.X,6.X,7.X and 8.X.
Many Thanks
Jaime Valencia
Cisco Unified Communications Manager: New or  Enhanced Features, by Version
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/ps10662/sales_tool_c96-592658.html
Further information can be found in the RNs for each version.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
