CCM version to support 7942G and 7937G
sivakumar.kvp
Hi to everyone,
The current version of CCM is 4.2(1)SR1b and the requirement here is to support 7942G and 7937G phone models.
It would be greatful if you guys help me here to find out the exact stable CCM version to support both phone models.
thanks
siva
Rob Huffman
Hi Siva,
Don't forget that CCM 4.2(3) is near it's EoL
EOS/EOL for the Cisco Unified CallManager Version 4.2
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps556/prod_end-of-life_notice0900aecd806ec7a2.html
The 7937G is supported in CCM 4.2(3) with the SR (SR2) and Device Pack (DevPack-36 or later) listed below. Once these upgrades are done the 7937 will be added to the available "Add a new Phone" selections (and Device Defaults Page);
Compatible Cisco Unified CallManager Release - 7937G
Note: If you have a Cisco Unified CallManager on a Release earlier than 4.1(3)SR5, do NOT install this firmware. You must first upgrade your Cisco Unified CallManager to one of the compatible releases listed
4.1(3)SR5
ciscocm.4-1-DevPack-59 or later
4.2(3)SR2
ciscocm.4-2-3-DevPack-36 or later
4.3(1)
ciscocm.4-3-1-DevPack-16 or later
5.1(2)
cmterm-devicepack5.1.2.3111-1 or later
5.1(3)
cmterm-devicepack5.1.3.1104 or later
6.0(1)
cmterm-devicepack6.0.1.2111-1 or later
6.1
No device pack required, native support
From the Cisco Unified IP Conference Station 7937G Firmware Version 1.1(1) - ReadMe;
http://download-sj.cisco.com/cisco/voice/ip-7900ser/cmterm-7937-sccp.1-1-1-readme.htm
7942G Call Control Compatibility
Supported in Cisco Unified Communications Manager Versions 4.1(3)sr5b, 4.2(3)sr2b, 4.3(1), 5.1.1(b), 5.1(2), 6.0(1) and greater
Supported in Cisco Unified Communications Express and SRST Version 4.1
Cisco Unified IP Phone 7942G
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps8535/product_data_sheet0900aecd8069bb68.html
Hope this helps!
Rob
Hi Rob,
Thanks for your immediate reply.
Here am summarizing,
7937G - 4.2(3)SR2  (DevPack-36 or later)
7942G - 4.2(3)SR2b
What i understand here is, i can upgrade to 4.2(3)SR2b with DevPack-36 or later to support 7937G ; pls correct me if am wrong ?
Secondly, i dont see any upgrade path from  4.2(1)SR1b to 4.2(3)SR2b.Request you to guide me here as well pls.
thanks
siva
William Bell
I would look at Device Pack 4.2.3-60. Requires a minimum of 4.2(3)SR1.
Check out the following URL:
http://www.cisco.com/web/software/282074299/26745/ciscocm.4-2-3-DevPack-60_r
eadme.html
Remember that if you are using a device pack to add new devices to the
schema then you will need to reboot the entire cluster.
HTH.
Bill
On 9/14/10 10:08 AM, "sivakumar.kvp"
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
raghu_pmj
Need to upgrade the call manager from existing version to 4.2(3)sr2b which would support 7942 IP phones. The patch is available on below URL
http://www.cisco.com/cisco/software/release.html?mdfid=280264388&flowid=5321&softwareid=282074295&release=4.2(3)SR2b&rellifecycle=&relind=AVAILABLE&reltype=all
Before proceed on upgradation, take the backup of call manager using BARS 4.0.12 or 4.0.13 version.
