VIP Super Bronze
CCM version
How do I check the CCM version without login in to the CCMAdmin page. I have problems login to a sub, I guess its a version problem. Please How do I get the version without the Admin page
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: CCM version
If it's CM 4.X and earlier you can go to registery
Software\Cisco Systems Inc\Callmanager\Patches\Patch Name
you should see something like:
4.1(3)sr4d
HTH,
Chris
Re: CCM version
4.1(3)sr4d
HTH,
Chris
Gold
Re: CCM version
To know what is the current version installed on the box along with all the installs the server has had, you can go to C:\Program Files\Common Files\Cisco\Logs\history.txt. This file would let details about each patch/upgrade installed on the box from the time the box was installed.
VIP Super Bronze
Re: CCM version
Thank you
87
