CCM with AA
i have CCM 4.1 with AA co-exist.
On the voice gateway (PSTN) i have a voip dial peer pointing to 6000 which is the CTI route point of the AA. evrything is working fine, the problem happens in SRST mode where CCM is down and 6000 is not reachable!!!
i tried to configure uknown extension under the srst but did not work. I am sure there is a way to do it!!!
Good day
1 ACCEPTED SOLUTION
Re: CCM with AA
Wissam,
You can configure a TCL script to use a voice dial-peer voip. The configuration will look very similiar to your original dial-peer to CCM but with the addition of the 'service' command and pointing the 'session target ipv4:x.x.x.x' to a loopback on the router.
Here is an example
dial-peer voice 6001 voip
service aa
preference 1
destination-pattern 6000
!Loopback IP
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Also most of the time when this is done you will need to turn on the IP-to-IP GW for H323 or SIP depending on if you route out again from your AA.
voice service voip
allow-connections h323 to sip
Please rate any helpful posts
Fred
Gold
Re: CCM with AA
You can use the AA TCL script on the router to achieve this. Based on the IOS version you have on the router, you can download the srst files from http://www.cisco.com/cgi-bin/tablebuild.pl/ip-key and use them on the SRST router. The SRST file should even have a ReadMe included which has instructions on how to go about with the config.
Hope that helps.
Re: CCM with AA
thanks but i have CCM and not CME. I have once configured CME with a TCL, but i do not see how it will help in my case.
I mean on the FXO port i have the following:
voice-port 0/0/0
connection plar opx 6000
dial-peer voice 6000 voip
session target ipv4: CCMIP
if CMMIP is not reachable!! what's next
Good day
Gold
Re: CCM with AA
TCL Script works on both CME and SRST. So, you can add a 2nd dial-peer for 6000 and configure it launch SRST and use "preference 1" along with no huntstop on dial-peer 6000. Therefore when dial-peer 6000 fails, it should hit the 2nd dial-peer which has been configured for SRST
Re: CCM with AA
it make more sense, but up to my knowledge, the TCL configuration i use it under Dial-peer pots (service autoattenant for instance) so how i will make sure it will hit my dial-peer.
If you have a configuration sample it would be greate.
Good day
Re: CCM with AA
Wissam,
Here is an example
service aa
preference 1
!Loopback IP
codec g711ulaw
no vad
voice service voip
Fred
Re: CCM with AA
thanks a lot.
It really helps very much.
Good day
141
