CCM4.3(1) upgrade to CCM4.3
what is the procedue upgrade my CCM4.3(1) to latest CCM4.3 version. Including cisco secuirty agent and csa policy.
Can some one provide the procude for the upgrade?
Re: CCM4.3(1) upgrade to CCM4.3
Hi Sunish,
Yes i already download all thing that you mention. Before upgrade I will perform backup.
I just have to double click the CCM4.3(2)SR1C then follow instruction from the scrren until finish maybe require reboot. Then continue with the CSA and CSA policy upgrade.
Correct me if I am wrong. Is Cisco provide any guide for this?
It's a wizard as the one you use to install anything on a PC.
Just run the program and follow the instructions.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Java,
thank you so much for the advice. So far do you face any risk or problem during the upgrade?
171
