ccm5.0 + ios hardware CFB & MTP
Dear Sir,
I try to add the ios hardware CFb & MTP on ccm 5.0, but it is shown us "reject".
Could anyone advise it.
thanks
KH
the router setting as
sccp local GigabitEthernet0/0
sccp ccm 11.24.68.10 identifier 1
sccp ccm 11.24.68.11 identifier 2
sccp
sccp ccm group 1
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 1 register CFB001a6da80a28
associate profile 2 register MTP001a6da80a28
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
maximum sessions 4
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
Bronze
Re: ccm5.0 + ios hardware CFB & MTP
Try the following steps to resolve the issue:
1) Change to IOS enhanced.
2) Reset CFB in CCMAdmin.
3) Configure "no dspfarm" on the voice-card.
5) Give "no sccp", and then "sccp". Now give "no dspfarm" and then "dspfarm" (global command).
6) Conference bridge needs to be configured as "Cisco IOS Enhanced Conference Bridge Hardware"
7) Reset CFB again in CCMAdmin after each change.
Silver
About this command;
It should be"
voice-card #
no dspfarm
dsp services dspfarm
In order to enable the DSP-farm services for the voice card.
Check this link:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/vvfax_c/callc_c/ccm_c/intcnf2.htm
Try add version of CCM in following commands
sccp ccm 11.24.68.10 identifier 1 version5.0.1
sccp ccm 11.24.68.11 identifier 2 verison 5.0.1
BR
MC
I am having the same exact problem right now. Did placing the version on the IOS fix this?
I am facing the same problem, did u manage to resolve it and how?
George G
If u r using the PVDM2 in motherboard for the DSPfarm the minimum IOS version required is 12.3(11)T. I think then only u will get the option Version CCM 5.0.1 in SCCP CCM Identifier version .. command.
and u can use these commands for troubleshooting..
1. show running-config
2. show sccp ccm group [group-number]
3. show dspfarm profile [profile-number]
4. show dspfarm all
5. show sccp
6. show sccp connections
7. show media resource status
You must put the version at the end of the line as shown above, that is how I fixed it.
Silver
For this to work on CCM 5.X and 6.X, you should use the version 4.1, it should look like this:
sccp ccm 11.24.68.10 identifier 1 version 4.1
espereir ..that did help..thx a lot !!!
396
