CCM5, can I have different rington on 2nd line?
I want to have a ringtone on 2nd line from ringlist.xml.
Advise please.
Thanks in advance,
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CCM5, can I have different rington on 2nd line?
Hi John,
This setting is done on the phone itself. Via Settings>User Preferences>Rings
Once there you can select the Line that you want to set a ring for and Select>Play>Select>Save>Exit
And "Bob's your Uncle"!
Hope this helps!
Rob
Hi John,
Sadly you can only use one of the seven "built-in" rings for the "Distinctive Ring per Line" feature. This was first added in CCM 3.3 and has not changed :( Here is a clip from the CCM 3.3 Release notes;
This release adds support for seven distinctive ring patterns to Cisco IP phones 7914, 7940, or 7960. Phone users with multiline phones can configure a distinctive ring pattern for each line on the basis of a logical precedence or importance.
Hope this helps!
Rob
Thanks Rob,
seven built-in rings is enough to me but I cannot find out a parameter to set the 'distinctive ring' on DN configuation. how can I set?
John.
Hi John,
Hope this helps!
Rob
148
