04-27-2008 05:47 AM - edited 03-15-2019 10:19 AM
We have a problem in regestering our CCM 5.0 and the 3845 voice GW router, the CCM shows the router as unregestered with the IP Address, and the router I noticed that I'm not able to show the MGCP endpoints. please how can I verify or point to the problem.
04-27-2008 09:06 AM
verify your config, maybe you're missing the service mgcp under the pri-group.
maybe the dial-peers do not have the application mgcpapp commmand.
maybe you selected the wrong slot.
if possible post your config
javalenc
if this helps, please rate
04-27-2008 11:29 PM
thanks, we are using BRI interfaces, below is the router configuration:
voice service voip
allow-connections h323 to sip
supplementary-service h450.12
h323
voice class codec 1
codec preference 1 g729r8
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.65.60.4
ccm-manager config
username admin password 0 ad-tech123
interface GigabitEthernet0/0
ip address 10.65.60.5 255.255.255.0
duplex auto
speed auto
media-type rj45
interface Service-Engine0/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.65.60.6 255.255.255.0
service-module ip default-gateway 10.65.60.1
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/0/0
no ip address
shutdown
clockrate 2000000
interface Serial0/0/1
no ip address
shutdown
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
interface BRI0/1/1
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 10.65.60.1
ip route 10.65.60.6 255.255.255.255 Service-Engine0/0
ip http server
no ip http secure-server
control-plane
voice-port 0/1/0
compand-type a-law
cptone JO
timeouts interdigit 3
connection plar 199
voice-port 0/1/1
compand-type a-law
cptone JO
connection plar 199
mgcp
mgcp call-agent GetCCM 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 3 voip
destination-pattern [1-4]..
session protocol sipv2
session target ipv4:10.65.60.6
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1 pots
application mgcpapp
port 0/1/0
dial-peer voice 2 pots
application mgcpapp
port 0/1/1
dial-peer voice 100 pots
preference 1
destination-pattern 9T
port 0/1/0
dial-peer voice 101 pots
preference 2
port 0/1/1
end.
04-27-2008 11:29 PM
and here below some result for debug mgcp:
*Apr 28 07:28:34.903: mgcpapp_process_mgcp_msg : socket drained.
*Apr 28 07:28:34.903: MGCP sys msg: (15)
*Apr 28 07:28:34.903: xlate sys msg: (15, 65532148)
*Apr 28 07:28:34.903: sys msg values: (INVALID MGCP EVENT, 65280, , 1619485180, CALL_IDLE)
*Apr 28 07:28:34.903: process mgcp_handle_cmapp_event
*Apr 28 07:28:34.903: mgcp_cmapp_send_keepalive send NTFY KeepAlive
*Apr 28 07:28:34.903: xgcp_endpt_get_by_ifn
*Apr 28 07:28:34.903: xgcp_endpt_get_tree_link_by_ifn
*Apr 28 07:28:34.903: xgcp_endpt_compute_key- type -1 slot -1 subunit 58
*Apr 28 07:28:34.903: xgcp_endpt_get_tree_link_by_ifn : computed key 0x0xF0000000
*Apr 28 07:28:34.903: send_mgcp_empty_notify_msg: endpt *, complete_endpt *@getmgcp.getecom.com
*Apr 28 07:28:34.903: -- mgcp_build_packet()-
*Apr 28 07:28:34.903: - mgcp_estimate_msg_buf_length() - 328 bytes needed for header
- mgcp_estimate_msg_buf_length() - 373 bytes needed after checking parameter lines
- mgcp_estimate_msg_buf_length() - 373 bytes needed after cheking SDP lines
*Apr 28 07:28:34.903: --- mgcp_build_parameter_lines() ---
- mgcp_val_mandatory_parms()
- mgcp_build_request_id()
- SUCCESS: Request ID string building is OK
- mgcp_build_obs_events()
- mgcp_build_obs_events()- mp_head_obs_evt_list NOT NULL
- mgcp_build_obs_events()- out of for loop for next node in list
- SUCCESS: Building MGCP Parameter lines is OK
*Apr 28 07:28:34.903: - SUCCESS: MGCP message building OK
*Apr 28 07:28:34.903: - SUCCESS: END of building
*Apr 28 07:28:34.903: * mgcp_get_ca_addr_port:
*Apr 28 07:28:34.903: * mgcp_get_ca_addr_port: Used endpoint NE 10.65.60.4:2427
*Apr 28 07:28:34.903: * mgcp_get_ca_addr_port: NE addr 10.65.60.4:2427
*Apr 28 07:28:34.903: * mgcp_enq_retx_msg: trans_id 59,ntfy_ent 10.65.60.4:2427
*Apr 28 07:28:34.903: * mgcp_root_get_profile:
*Apr 28 07:28:34.903: mgcp_add_trans_id_rec: Add trans id (59, 648ECC30) record
*Apr 28 07:28:34.903: mgcp_stw_timer_start timer type 0, duration 500
*Apr 28 07:28:34.903: MGCP Packet sent to 10.65.60.4:2427--->
NTFY 59 *@getmgcp.getecom.com MGCP 0.1
X: 0
O:
*Apr 28 07:28:34.903: send_mgcp_empty_notify_msg NTFY Packet sent successfully - *
*Apr 28 07:28:34.903: MGC stat - 10.65.60.4, total=67, succ=42, failed=24
*Apr 28 07:28:34.903: MGCP Packet received from 10.65.60.4:2427--->
200 59
*Apr 28 07:28:34.903: mgcpapp_process_mgcp_msg : processing received message.
*Apr 28 07:28:34.903: -- mgcp_parse_packet() - call mgcp_parse_header
*Apr 28 07:28:34.903: mgcp_parse_response : 200 59
*Apr 28 07:28:34.903: mgcp_string_parse: return code=1.- mgcp_parse_packet() - out mgcp_parse_header
- SUCCESS: mgcp_parse_packet()- MGCP Header parsing was OK
- SUCCESS: mgcp_parse_packet()- END of Parsing
*Apr 28 07:28:34.903: * mgcp_msg_ack
*Apr 28 07:28:34.903: MGC stat - 10.65.60.4, total=67, succ=43, failed=24
*Apr 28 07:28:34.903: * mgcp_msg_ack: Removing msg : NTFY 59 *@getmgcp.getecom.com MGCP 0.1
X: 0
O:
*Apr 28 07:28:34.903: * mgcp_msg_ack: Setting the restart method to NONE
*Apr 28 07:28:34.903: mgcpapp_process_socket
