CCM6.01 2811 FXS port no dial tone off hook
Using MGCP from CCM6.0 to a 2811 rtr with a 4 port FXS module. Analog phone goes off hook no dial tone. I can make calls to and from this port no problem at all but no dial tone off hook.
Anyone have any ideas?
Re: CCM6.01 2811 FXS port no dial tone off hook
Are these fxs port registered to callmanager?
'show ccm'
'show mgcp endpoints db'
You can try removing the mgcp dial-peers associated to one of the fxs ports, then take the phone off hook from that port and see if there's dialtone.
If so you may need to check the mgcp configuration.
If not do a 'show voice port summ' and check the status of these ports.
may want to enable debug vpm signal too when going offhook.
Yes
Primary Registered 192.168.7.10
First Backup None
Second Backup None
Current active Call Manager: 192.168.7.10
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 21:35:42 UTC Feb 10 2008 (elapsed time: 00:00:13
Last MGCP traffic time: 21:35:42 UTC Feb 10 2008 (elapsed time: 00:00:13
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: None
Last MGCP Fallback end time: None
MGCP Download Tones: Disabled
Configuration Auto-Download Information
Current version-id: 1202678993-f0f0eb3c-73f7-449d-95fb-40f9c7d2c849
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
Download Attempted : 4
Download Successful : 4
Download Failed : 0
TFTP Download Failed : 12
Configuration Attempted : 4
Configuration Successful : 4
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: cisco
Configuration Error History:
MESAVGW#sh mgcp endpoint db
Endpoint Name Type State NC Ext
aaln/S0/SU0/0 Analog Ready 0 192.168.7.10:2427 0 F
aaln/S0/SU0/1 Analog Ready 0 192.168.7.10:2427 0 F
aaln/S0/SU0/2 Analog Ready 0 192.168.7.10:2427 0 F
aaln/S0/SU0/3 Analog Ready 0 192.168.7.10:2427 0 F
aaln/S0/SU0/* SU NA 4 192.168.7.10:2427 0 F
aaln/S0/SU1/0 Analog Ready 0 192.168.7.10:2427 0 F
aaln/S0/SU1/* SU NA 1 192.168.7.10:2427 0 F
aaln/S0/SU*/* Slot NA 2 192.168.7.10:2427 0 F
aaln/S*/SU*/* AALN NA 1 192.168.7.10:2427 0 F
* Root NA 1 192.168.7.10:2427 0 F
0/1/0 is the FXS port I am testing with.
It's registered just when I make a call in either direction the phones ring but no audio or progress tones when off hook.
Debug VPM signal going offhook onhook
*Feb 10 22:01:12.843: htsp_process_event: [0/1/0, FXSLS_ONHOOK, E_DSP_SIG_1100]f
xsls_onhook_offhook htsp_setup_ind
*Feb 10 22:01:12.843: [0/1/0] get_local_station_id calling num= calling name= ca
lling time=02/10 22:01 orig called=
*Feb 10 22:01:12.843: TGRM: reg_invoke_tgrm_accept_call(1, TGRM_CALL_VOICE, TGRM
_DIRECTION_IN, 0, 1, 0, 65535)
*Feb 10 22:01:12.843: TGRM: Calling vtsp_tsp_call_setup_ind().
*Feb 10 22:01:12.843: TGRM: reg_invoke_tgrm_call_update(0, 1, 0, 65535, 1, TGRM_
CALL_BUSY, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
*Feb 10 22:01:12.851: dsp_digit_collect_off: [0/1/0] packet_len=8 channel_id=133
packet_id=36htsp_connect: no_offhook 0 call_connected 0
*Feb 10 22:01:12.855: htsp_process_event: [0/1/0, FXSLS_WAIT_SETUP_ACK, E_HTSP_S
ETUP_ACK]fxsls_check_auto_call
*Feb 10 22:01:12.855: htsp_process_event: [0/1/0, FXSLS_OFFHOOK, E_HTSP_CONNECT]
fxsls_offhook_connect
*Feb 10 22:01:12.855: [0/1/0] set signal state = 0x6 timestamp = 0
*Feb 10 22:01:12.855: dsp_set_sig_state: [0/1/0] packet_len=12 channel_id=133 pa
cket_id=39 state=0x6 timestamp=0x0
*Feb 10 22:01:49.151: htsp_process_event: [0/1/0, FXSLS_CONNECT, E_DSP_SIG_0100]
fxsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Feb 10 22:01:49.151: htsp_timer - 1000 msec
*Feb 10 22:01:50.151: htsp_process_event: [0/1/0, FXSLS_CONNECT, E_HTSP_EVENT_TI
MER]fxsls_connect_wait_release_req
*Feb 10 22:01:50.151: htsp_timer_stop
*Feb 10 22:01:50.151: htsp_timer_stop3 htsp_release_req: cause 16, no_onhook 0
*Feb 10 22:01:50.151: htsp_process_event: [0/1/0, FXSLS_WAIT_RELEASE_REQ, E_HTSP
_RELEASE_REQ]fxsls_waitrls_req_rls
*Feb 10 22:01:50.151: [0/1/0] set signal state = 0x4 timestamp = 0
*Feb 10 22:01:50.151: dsp_set_sig_state: [0/1/0] packet_len=12 channel_id=133 pa
cket_id=39 state=0x4 timestamp=0x0
*Feb 10 22:01:50.155: dsp_set_sig_state: [0/1/0] packet_len=12 channel_id=133 pa
*Feb 10 22:01:50.155: TGRM: reg_invoke_tgrm_call_update(0, 1, 0, 65535, 1, TGRM_
CALL_IDLE, TGRM_CALL_VOICE, TGRM_DIRECTION_IN)
*Feb 10 22:01:50.155: flex_dsprm_close_cleanuphtsp_allocate_if --
*Feb 10 22:01:50.163: HTSP endpoint_info=aaln/S0/SU1/0, type=2, under_specified
=0,
service_type=2htsp_allocate_if: MATCH!
*Feb 10 22:01:50.167: htsp_validate_cap
*Feb 10 22:01:50.167: flex_modem_relay_supported:Modem Relay supported. flex_typ
e=1
you may need to add the 'mgcp bind' commands to the gateway if you don't have it yet.
e.g.
conf t
mgcp bind media source-interface fa 0/0
no mgcp
mgcp
I had the same problem. I deleted the lines from the MGCP config, then did a no mgcp mgcp...readded the lines...did no mgcp mgcp and it worked.
751
