CCM6 and IP communicator
I can not get IP communicator to work for nothing. The status keeps saying TFTP Timeout 7A.cnf.xml and CTL update failed. I have tftp service running as well as other services.
Finally, my other question is when I click on Cisco Unified Serviceabilities and then Control Center - Feature Services and when I click refresh sometimes the status is not running for CCM and TFTP even though they are activated? Thanks guys.
Green
Re: CCM6 and IP communicator
Do you have all Licenses in CallManager?
DLU for phones
Node Licenses and SW licenses?
Other IP Phones are registered>?
I work for a Cisco partner and we were given a demo copy of CCM6. I'm assuming the licenses are already installed or do I have to install the demo 50 licenses somehow? Thanks for your help.
I had exactly this problem. Reinstalling Communicator 3 times (and not changing any CCM settings)solved it. I even had Communicator crashing repeatedly.
Hope this helps.
330
