04-20-2010 05:56 AM - edited 03-15-2019 10:21 PM
I've configured a CCM with a voice gatway that use E1 PRI.
CCM use SIP and MGCP to make outbound call through the voice gateway.
I will use MGCP at the end. The SIP is just for temporary test.
Question : How to display the called numbe when the E1 port is managed by MGCP?
1/ If I use SIP I can see the called number when I do the show voice call status command
2/ If I use MGCP,then I cannot see the called number when using this same command.
I'm using the voice call status for troubleshooting
Description | CallID | CallID | ccVdb | Port | DSP/Ch | Called # | Codec | Dial-peers |
SIP call | 0x979B7 | 33C5 | 0x483A9C40 | 0/2/0:15.23 | 0/6:1 | *033140599 | g711ulaw | 0/51 |
MGCP call | 0x979D2 | 11E2 | 0x483AB680 | 0/3/0:15.31 | 0/3:6 | * | g711ulaw | 0/0 |
SIP call | 0x97AEB | 362B | 0x483A9C40 | 0/2/0:15.21 | 0/6:6 | *0320413446 | g711ulaw | 0/51 |
Is there any solution?
Or I have to see the CDR? But its result is not instantly
Best regards,
Antra
04-20-2010 06:28 AM
Have you tried "show isdn active"
04-20-2010 06:37 AM
I've tried, but it just show the calls that use SIP calls :
All calls that display star and nothing after are calls made from MGCP
rtVg00#sh voice call status
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0x9880F FB3 0x483A9C40 0/2/0:15.25 0/5:1 *0320418297 g711ulaw 0/51
0x98ABB 12ED 0x483AB680 0/3/0:15.27 0/3:5 * g711ulaw 0/0
0x98ADA 13E2 0x483A9C40 0/2/0:15.27 0/6:6 *0320262734 g711ulaw 0/51
0x98AE7 12F8 0x483AB680 0/3/0:15.31 0/3:1 * g711ulaw 0/0
0x98AEB 12F9 0x483AB680 0/3/0:15.30 0/3:3 * g711ulaw 0/0
0x98AEF 12FA 0x483AB680 0/3/0:15.25 0/6:2 * g711ulaw 0/0
0x98AF7 12FC 0x483AB680 0/3/0:15.28 0/6:5 * g711ulaw 0/0
0x98AFA 1412 0x483A9C40 0/2/0:15.22 0/4:4 *0320263654 g711ulaw 0/51
0x98B02 141E 0x483A9C40 0/2/0:15.26 0/5:3 *0331184452 g711ulaw 0/51
0x98B26 1454 0x483A9C40 0/2/0:15.21 0/4:5 *0327615059 g711ulaw 0/51
0x98B43 130F 0x483AB680 0/3/0:15.24 0/4:1 * g711ulaw 0/0
0x98B57 1314 0x483AB680 0/3/0:15.22 0/6:4 * g711ulaw 0/0
0x98B7A 14D2 0x483A9C40 0/2/0:15.31 0/3:2 *0320267304 g711ulaw 0/51
13 active calls found
ORArtVg00#show isdn active
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
Out 90017 0320262734 90 Unavail - 0
Out 90218 0331184452 69 Unavail - 0
Out 90016 0320263654 63 Unavail - 0
Out 90045 0327615059 35 Unavail - 0
rtVg00#
04-20-2010 07:16 AM
Then you need to run a "debug isdn q931" and be sure you can see the Calling and called number from the MGCP gateway.
04-20-2010 07:08 AM
This appers in the show isdn status
rtVg00#sh isdn status
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/2/1:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 5
This is the config in the controllers :
controller E1 0/2/1
framing NO-CRC4
clock source internal
pri-group timeslots 1-31 service mgcp
description Test E1 PRI
interface Serial0/2/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
