09-17-2008 02:33 AM - edited 03-15-2019 01:19 PM
if i want to login per web into the CCM i get a "Database communication error". Can i rebuild the database to factory default?
I Think this error followed by changing the CCM Ip address.
regards
Ronny
Solved! Go to Solution.
09-17-2008 03:39 AM
Hi, had the same issue - didn't read the doc :-)
- Change the IP address back to what it was.
- Login (should work again)
- Change IP on Web page (System/Server) BEFORE you change the IP on CLI
- change IP on CLI
- reboot
- ccmadmin login works
Cheers,
Martin
09-17-2008 03:39 AM
- change IP on CLI
- reboot
Cheers,
Martin
