VIP Super Bronze
CCM7.0(1) Called party Tranformation Pattern
I am trying to use the "called party transformation pattern " on CCM 7.0(1) to manipulate my called number..
Eg I have a RP of 8.[2-9]XXXXXX and I created a called party xform pattern of 8.[2-9]XXXXXX, with a discard digit =predot and called number prefix of 9, so that I can prefix 9 on the called number.
For some reason callmanager is not xforming the called number. I am using this with device nobility so that roaming users can preserve their dialing pattern from their home location.
I have the checkbox "use device pool called party xformation css" checked on the gateway and I have also assign the required "called party xformation css" to the device pool.
Any help will be appreciated.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: CCM7.0(1) Called party Tranformation Pattern
Why are you using xform mask, you can discard predot digit and add prefix in RP
Community Member
One of my peers had same issue and it was a BUG. he called TAc. Not sure of bug id sorry
135
