CCM7 cluster
I have a 3 site cluster
site A has pub and sub1
site B sub2
site C sub3
All PSTN calls arrive at site A.
On the gateway for site A.
Should my dial-peer point to the Sub1 at site A. as the PUB is not doing call-processing?
or would it be better to point the site specific range at the relevant subscriber?
1 ACCEPTED SOLUTION
Re: CCM7 cluster
Yes, this is correct, any subscriber, as well as the publisher, can handle call processing.
Hope that helped, if so please rate.
Re: CCM7 cluster
Just configure your dial-peers using the "preference" statement, and point each of them to a subscriber, and point the one with the lowest preference to the pub. This way, if any of the subs are down, calls can still be processed by another subscriber. See example:
dial-peer voice 1 voip
destination-pattern .T
session target ipv4: [sub1 IP]
dtmf-relay h245-alphanumeric
dial-peer voice 2 voip
session target ipv4: [sub2 IP]
preference 1
dial-peer voice 3 voip
session target ipv4: [sub3 IP]
preference 2
dial-peer voice 4 voip
session target ipv4: [Pub IP]
preference 3
Re: CCM7 cluster
many thanks,
so if for example a PSTN call comes in on the gateway at site A and it is destined for a DDI at site C, any subscriber can do the call setup. It doesn't have to be done by sub3 at site C.
Re: CCM7 cluster
107
