CCMAdministrator and other account doesnt work for login
acerda
Hi All -
I was enable to login using the CCMAdmin and other account adminitrator on a cluster via web. It is intregrated with active directory.
Please guide me for get login again.
Thanks in advance
Andres
rerun the AD integration then
java
if this helps, please rate
java
Jaime Valencia
try resetting the pwd using the ccmpwdchanger tool
Active Directory and Cisco CallManager Integration Troubleshooting Guide [Cisco Unified Communications Manager (CallManager)]
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d3c48.shtml
java
java
OK Java
The issue is that I can login to others CUCM clusters with same CCMadmin user/pass in the newtwork.
Let you know
Andres
java
java
