Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
ccme 075 mobile numbers
hello,how do i enable users to dial 075 mobile numbers from the phones.They can dial other mobile numbers ok.
System is callmanager express 4.1.0.1 in the UK
Re: ccme 075 mobile numbers
Look for a POTs DP within your configuration which looks similar to the following:-
dial-peer voice 100 pots
destination-pattern 907[7-9]........
forward-digits 11
Amend the destination-pattern to
907[57-9]........
Hope this helps.
Allan.
Thanks Allan, will do.
111
