CCME 4.0.3 Caller hears ring when Call Parked
I have had several customers "complain" with the fact that: when a call is parked in CCME, the caller hears a ring. This becomes confusing for some customers when they call in. Is there a way to disable this behavior?
Hall of Fame Super Gold
Re: CCME 4.0.3 Caller hears ring when Call Parked
have you tried to listen to this yourself ? Which version of IOS are theu using?
I have not configured call park myself, but from logic I think the parked caller should hear music on hold, or the faint "beep-beep" if MOH is not configured.
It is 12.4.4(XC) and I have heard it myself at two different installations. (CME 4.0.3). you hear the ring right as you're being parked and right before the person picks it up.
So is not a continuous ringback ?
What do you hear between these ringbacks ?
It seems reasonable to me that you hear a ringback when parked and when going out as an advice the call is being treated in some special way.
In between, it is just MOH as expected. And I understand the reasoning too. However, CCM does not do it and I have had two customers with real issues because the callers "get confused" (one customer is a brokerage house).
So I'm looking to see if there is a way to disable the ring-back.
I can agree the ringback before getting MOH is opinable.
But the ringback before getting connected, I think it makes a lot of sense. I've heard it many times when calling customer service for many companies.
I think the meaning is, if you are on speakerphone doing something else, pick up now, as you're being connected.
100
