CCME 4.0 not workingCOR
Hio Folks anyone got time to take a look why COR is not working ? config below thanks regardless of configuration calls can be made to IDD even if they are not allowed, any advice seems like a bug ?
dial-peer cor custom
name Local
name STD
name IDD
name Mobile
name Emergency
dial-peer cor list CallLocal
member Local
member Emergency
dial-peer cor list CallSTD
member Local
member STD
member Emergency
dial-peer cor list CallMobile
member Local
member Mobile
member Emergency
dial-peer cor list CallIDD
member Local
member STD
member IDD
member Mobile
member Emergency
dial-peer cor list Mobile
member Mobile
member Emergency
dial-peer cor list CallEmergency
member Emergency
dial-peer voice 1 pots
description Incoming calls
incoming called-number .
direct-inward-dial
port 0/1/0:15
forward-digits 0
dial-peer voice 2 pots
description OUTGOING Dial-Peer for Port 0/1/0:15
destination-pattern 0T
port 0/1/0:15
dial-peer voice 3 pots
corlist outgoing CallLocal
description 13xxxx numbers
destination-pattern 013[1-9]...
port 0/1/0:15
forward-digits 6
dial-peer voice 5 pots
description 1800XXXXXX numbers
destination-pattern 01800......
port 0/1/0:15
forward-digits 10
dial-peer voice 6 pots
corlist outgoing CallEmergency
description - emergency
destination-pattern 0000
port 0/1/0:15
forward-digits 3
dial-peer voice 7 pots
corlist outgoing CallSTD
description STD numbers
destination-pattern 0[3,5-9].......
port 0/1/0:15
forward-digits 8
dial-peer voice 8 pots
description 1300xxxxxx numbers
destination-pattern 01300......
port 0/1/0:15
forward-digits 10
dial-peer voice 9 pots
description National (STD) calls
destination-pattern 00[2,3,5-9]........
port 0/1/0:15
forward-digits 10
dial-peer voice 10 pots
corlist outgoing CallIDD
description International calls
destination-pattern 00011T
port 0/1/0:15
prefix 0011
dial-peer voice 11 pots
destination-pattern 0[2,3,5-9].......
port 0/1/0:15
forward-digits 8
dial-peer voice 12 pots
corlist outgoing CallMobile
description Dial Mobiles 04xx-xxx-xxx
destination-pattern 004........
port 0/1/0:15
forward-digits 10
dial-peer voice 13 pots
description Local 02XXXXXXXX
destination-pattern 00[2]........
port 0/1/0:15
forward-digits 8
telephony-service
load 7960-7940 P00308000300
load 7914 S00103020003
load 7912 CP7912080001SCCP051117A
max-ephones 96
max-dn 288
ip source-address 10.162.18.1 port 2000
max-redirect 20
timeouts interdigit 5
system message Pilkington - Wetherill Park
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 679 extension-length 1 extension-pattern 9 no-reg
voicemail 699
max-conferences 6 gain -6
moh music-on-hold.au
web admin system name admin password cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 0
create cnf-files version-stamp 7960 Jan 18 2007 14:14:06
ephone-dn 1 dual-line
number 600
label Ross Fagan
description Ross Fagan
name Ross Fagan
call-forward busy 699
call-forward noan 699 timeout 10
corlist incoming CallIDD
hold-alert 30 originator
ephone-dn 2 dual-line
corlist incoming CallMobile
number 640
label Daniel Black
description Daniel Black
name Daniel Black
Re: CCME 4.0 not workingCOR
Henry,
Its not very clear in the post as to which phone you are having this trouble with. Say for ex: with your configuration ephone-dn 1 has Cor list CALLIDD applied. Since this is a superset of all other COR lists, this phone will be able to call using any of the dial-peers. While ephone 2 should only be able to call Local, Mobile and Emergency only.
COR list rule of thumb
If the incoming cor list is a superset of outgoing, call is allowed. If incoming cor is not a superset, call is denied. In any other combination where there is no incoming or no outgoing cor lists, or both, call is allowed by default.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Sankar
PS: please remember to rate posts!
Hi thanks for your reply yes ephone 2 can dial any number regardless of the fact I have applied a cor that allows only local, mobile and emergency ? I am confused by your last sentence, it has worked in the past on other installs,
yeap ephine 2 call call any number regardless confused by COR list rule of thumb
Hi I fixed it by mistake I have a pots peer allowing all :) thanks mate
155
