Community Member
CCME 4.03 SIP Trunk to Asterisk
I'm configuring a 2801 CME 4.03 to a sip provider for PSTN. I can't get either outgoing or incoming calls to work even though the trunk appears to authenticate ok. Config is below for our test DDI no and ADSL line. Currently the incoming has no translation rules assigned - I just removed them.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
header-passing
registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g711ulaw
voice translation-rule 1
rule 1 /^90/ /0/
rule 2 /^80/ /0044/
voice translation-rule 2
rule 1 /^2.../ /01908888327/
voice translation-profile SIPout
translate calling 2
translate called 1
username xxx privilege 15 secret xxx
controller DSL 0/2/0
line-term cpe
translation-rule 1
Rule 0 ^90 0
translation-rule 2
Rule 0 ^100 01908888327
interface FastEthernet0/0
description LAN
ip address 10.10.10.200 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
description WAN
ip address 62.3.x.x.255.255.248
duplex auto
speed auto
ip route 0.0.0.0 0.0.x.x.3.199.177
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
tftp-server flash:TERM41.7-0-3-0S.loads
tftp-server flash:TERM70.7-0-3-0S.loads
tftp-server flash:term70.default.loads
tftp-server flash:CVM70.2-0-2-26.sbn
tftp-server flash:cnu70.2-7-6-26.sbn
tftp-server flash:Jar70.2-9-2-26.sbn
tftp-server flash:term41.default.loads
tftp-server flash:CVM41.2-0-2-26.sbn
tftp-server flash:cnu41.2-7-6-26.sbn
tftp-server flash:Jar41.2-9-2-26.sbn
tftp-server flash:term61.default.loads
tftp-server flash:TERM71.default.loads
control-plane
dial-peer voice 100 voip
description Outgoing Call via SIP
translation-profile outgoing SIPout
destination-pattern 9T
voice-class codec 1
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
dial-peer voice 101 voip
description Incoming call from VoIPTalk
voice-class codec 1
incoming called-number .%
dtmf-relay rtp-nte
no vad
sip-ua
authentication username xxx password xxx
no remote-party-id
retry invite 2
retry register 10
timers connect 100
mwi-server ipv4:217.14.132.178 expires 3600 port 5060 transport udp unsolicited
registrar ipv4:217.14.132.178 expires 3600
sip-server ipv4:217.14.132.178
telephony-service
load 7941 TERM41.7-0-3-0S
load 7970 TERM70.7-0-3-0S
max-ephones 24
max-dn 48
ip source-address 62.3.x.178 port 2000
auto assign 1 to 1
system message Crazy
network-locale GB
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
dn-webedit
transfer-system full-consult
transfer-pattern 9.T
secondary-dialtone 9
create cnf-files version-stamp 7960 Jan 02 2007 17:23:34
ephone-dn 1 dual-line
number 2000
label Test
description Test1
name Test1
ephone-dn 2 dual-line
number 2001
label Colour
description Colour
name Colour
ephone 1
username "Test" password 327
mac-address 0019.553B.BEEA
type 7941
button 1:1
ephone 2
username "xxx" password xxx
mac-address 0019.55DF.8B4E
type 7970
button 1:2
Please helps. Thank you Denise
1 REPLY
Community Member
Re: CCME 4.03 SIP Trunk to Asterisk
You have to have a dial-peer and an ephone-dn that are associated with that number
402
