01-07-2009 10:28 AM - edited 03-15-2019 03:22 PM
hi Do you know where is the step by step procedure to install the 2851 ccme router ? is it availble with ios and software package?
awating your response
01-07-2009 10:35 AM
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
You will need ipvoice or higher feature set, and IOS after 12.3 or so.
hth,
nick
01-07-2009 11:04 AM
Hi, you can check this guide for CCME installation and configuration.
Hope this help
David
01-07-2009 11:05 AM
Hi, jaja, sorry guys for the same message.
Best regards.
David
