Community Member
CCME 4.3 compatibity with CUE 3.0
Hello, I have a customer where we have to upgrade the CCME from version 4.2 to ver 4.3 in order to accomodate conference phone model 7937. The customer is also running Unity Express 3.0. My question, is CCME ver 4.3 compatible with CUE 3.0 OR should we also upgrade the CUE to the latest version. Thanks.
Chandrasen
Hall of Fame Super Gold
Re: CCME 4.3 compatibity with CUE 3.0
You should be fine with 3.0, they try to make so there are no dependencies.
Community Member
Thanks for the tip. I will upgrade the CCME to the latest version
Chandrasen
Community Member
Hi , Are you able to register 7937 to ccme 4.3 ? Can you please share if we need to make any workaround
Community Member
Hi to all,
According to CUE compatibility matrix to CCME. It should be min of 3.2 for CUE to be compatible with CCME ver. 4.3.
To all our Guru's, please clarify ..Thanks
Community Member
Thanks for the reply. We have already upgraded the CCME to 4.3 and the previous version of CUE, version 3.0 is working fine. No need to upgrade the CUE version 3.2.
Chandrasen
Community Member
Wow Great!!! ..Thanks for the reply.
157
