CCME and CUE problem
We are experiencing problems with single CCME and CUE configuration.
We have one H.323 voip trunk to local ISP with audio codec of G711alaw. Unfortunately our CUE uses G711ulaw, so incoming calls to CUE are dropped with cause code 41 (or 65 - Bearer capability not implemented). I made some test and with G711ulaw end-to-end everything is OK.
Our ISP cannot provide us Voip service using G711ulaw, so I tried to configure local transcoding.
Using show dspfarm all I can see that transcoding profile is UP and ASSOSIATED.
But incoming calls don't use this transcoding resource, so they are still dropped.
Any suggestion to resolve this issue?
Does Unity Express support G711alaw?
Thank you
Re: CCME and CUE problem
No, CUE does not support alaw. Can you send: 'show run | s dsp|telephony'
-nick
Thank you for the fast answer!
Here you can see requested information:
dspfarm
dsp services dspfarm
telephony-service ccm-compatible
tftp-server flash:dsp41.1-1-3-30.sbn
tftp-server flash:dsp11.1-1-3-30.sbn
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
codec g729r8
maximum sessions 6
associate application SCCP
telephony-service
load 7961 SCCP41.8-0-4SR2S
load 7911 SCCP11.8-0-4SR2S
max-ephones 96
max-dn 96 no-reg primary
ip source-address x.x.x.x port 2000
timeouts interdigit 7
system message XXX
sdspfarm units 1
sdspfarm transcode sessions 3
sdspfarm tag 1 mtp00070e72baf0
time-zone 28
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 XXXXX extension-length 5 extension-pattern XXXX
voicemail XXXX
max-conferences 8 gain -6
moh music-on-hold.au
web admin system name XXXX password XXXX
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 0
create cnf-files version-stamp 7960 Sep 24 2008 16:48:05
Thank you,
Svilen
Hi Svilen,
can you do a 'debug voip dialpeer', figure out your incoming and outgoing dial peers, and post those and your IOS version?
-nick
Thank you again :-)
Please find requested information attached to this post.
Incoming dial-peer 1:
dial-peer voice 1 voip
description incomming from ISP
translation-profile incoming ISP-IN
voice-class codec 1
voice-class h323 1
incoming called-number 0243419T
dtmf-relay rtp-nte cisco-rtp h245-alphanumeric
fax protocol pass-through g711alaw
Try taking the voice-class codec off, and either setting a hard g711alaw or g729r8. There were some IOS versions that had problems with that configuration.
-nick
Unfortunately it doesn't work again with g711alaw set up on incoming dial-peer:
voice-class h323 1
codec g711alaw
Thank you,
Svilen
what does dial peer 50090 look like?
dial-peer voice 50090 voip
description to VoiceMail pilot
translation-profile outgoing voicemail
destination-pattern 5009.
session protocol sipv2
session target ipv4:x.x.x.x
dtmf-relay sip-notify rtp-nte sip-kpml
codec g711ulaw
no vad
Configuration looks like it should work, you can try a 'no sccp' 'sccp' to reset the transcoder.
Thank you,
I tried to reset sccp, but calls are still dropped.
As I said early, transcoding resource is registered/associated and I beleive it is working (at this time I can't test it).
I want to do more or less the same thing ...
Did you finally succeed to configure your router/transcoder ?
Thanks you in advance,
Thierry
I have observed that to allow transcoding between H323 to H323, you may have to configure the following.
voice service voip
You may also have to hairpin the calls via a loopback address.
TF
228
