CCME and MTP
sistefanov
I have a question for CCME MTP configuration.
Does CCME supports MTP? And if it does, how to configure MTP for CCME?
I tried to configure it in same manner as transcoding resource.
Here is the output from show dspfarm all:
Dspfarm Profile Configuration
Profile ID = 2, Service = TRANSCODING, Resource ID = 2
Profile Description :
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 6
Number of Resource Available : 6
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Profile ID = 1, Service = MTP, Resource ID = 1
Profile Operation State : RESOURCE ALLOCATED
Application : SCCP Status : ASSOCIATION IN PROGRESS
Hardware Configured Resources : 6
Hardware Available Resources : 6
Software Resources : 0
Codec Configuration
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 1 9.2.3 UP N/A FREE mtp 1 - - -
0 1 9.2.3 UP N/A FREE xcode 2 - - -
0 2 9.2.3 UP N/A FREE xcode 2 - - -
Total number of DSPFARM DSP channel(s) 12
show sdspfarm units
mtp-1 Device:mtpXXXXXXXXXX TCP socket:[-1] UNREGISTERED
actual_stream:0 max_stream 0 IP:0.0.0.0 0 Unknown 0 keepalive 0
What is the reason MTP profile to be in "ASSOCIATION IN PROGRESS" status?
The main configuration is:
sccp local GigabitEthernetXXXX
sccp ccm 10.N.N.N identifier 1
sccp
sccp ccm group 1
bind interface GigabitEthernetXXXX
associate ccm 1 priority 1
associate profile 2 register tcxXXXXXXXXXXXX
associate profile 1 register mtpXXXXXXXXXXXX
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 6
associate application SCCP
dspfarm profile 1 mtp
codec g711ulaw
maximum sessions hardware 6
Thank you,
mciarfello
Level 4
Level 4
You need SDSPFARM commands under telephony-service.
sdspfarm units x
sdspfarm transcode sessions y
sdspfarm tag 1 mtpxxxxxxxxx (mac address)
sdspfarm tag 2 tcxxxxxxxxxx (mac address)
