CCME, ATA and Faxing
I have Cisco Call Manager running on a 2800 series router and have a Cisco ATA-186 (SCCP firmware) that I wish to use for a couple of faxes. I've tried adding the following lines to my configuration however whilst a fax answers an incoming call it does not seem to be able to negotiate with the sending fax & obviously fails. I cannot send outgoing faxes at all. Config lines:-
ephone-dn 24 dual-line
number 2214
description fax1
call-forward busy 600
call-forward noan 600 timeout 15
ephone 24
mac address xxxx.xxxx.xxxx
type ata
button 1:24
The ATA is also configured Audio Mode 0x00150015
Any one any ideas?
Re: CCME, ATA and Faxing
I think you must configure the fax relay or something like this.
ATA is capable to work only with fax passthrough. As I remeber previously using CME ATAs for fax transmission was only able in H.323 mode. So you have to change load on your ATA to H.323 and try this way.
Look into:
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a00800d698e.shtml
Wojtek
207
