CCME - block outgoing number just on one phone
can you block a specific number from being dialed from a specific phone?
  • IP Telephony
Re: CCME - block outgoing number just on one phone
Of course you can! Just use cor lists if this is a CME. Essentially they are CSS/PT setup for CME/SRST. cciev.wordpress.com has some config examples. or searching cisco.com for corlist should find some stuff..
HTH, please rate useful posts..
Chad
Hall of Fame Super Gold
A simple way is a translation-profile incoming for ephone-dn
voice translation-rule 10
rule 1 reject /5551234/
voice translation-profile block
translate called 10
Please rate post if it helps!
143
