CCME Call Blocking
Is there an easy way to block outbound calls w/ dial-peers? I need to block 205 specific numbers and can't use num-exp or after hours. Voip dial-peers to a bogus IP don't work because CCME ignores them if it can't connect to the IP. Any ideas?
Re: CCME Call Blocking
I guess you could use corlists
or
you could block calls 24/7 by issuing this command under telephony-services
after-hours block pattern 1 9900 7-24
This assumes you dial a 9 to get out it blocks calls to 900 numbers 7 days a week, 24 hours a day.
I already have some real complex cor lists in place. Any other way to do this?
Hmm..
Are you trying to block 205 different numbers or just numbers beginning with the digits 205 ?
I have to block 205 specific phone numbers.
I'm not sure if it's feasable for you but could in theory create an ephone-dn for each number but then not have it associated with any IP Phone button.
This might be out of the question because of the ammount of numbers you need to block. But it might be handy if you only needed to block a few.
Our sites are quite large with a lot of overlays so we can't fit another 205 ephone-dns in our config.
144
