04-24-2008 01:18 PM - edited 03-15-2019 10:17 AM
hi
i have CCME 4.0 in router 2811, the case is when i recive a PSTN call, i try tranfer it, i make the new call, and i heard the ring of the other phone, then i cancel the call and return with the previus call, and i still hear the ring tone of the cancel call,
why this possible?
06-25-2008 04:48 AM
HI all,
this bug willl resolve upgrating the IOS to 12.4T for IP telephony
06-25-2008 05:15 AM
Hi Eljose
Going from 12.4 XW to 12.4 T is actually a downgrade.
More correct would be update to XW8 first and check again.
06-25-2008 10:09 AM
We have just installed 12.4 11(wx8). We still are having the same issue on 7931s and 7960s.
06-25-2008 10:17 AM
Any chance you test FW 7.2.T23 at least on the 7960 ?
06-25-2008 10:20 AM
There is not any way we can do that because that is a downgrade from what we have now 8.0 (9.0) and we had to update to this because of issues with the earlier versions.
06-25-2008 11:55 AM
I can ensure you that 7.2.T23 has NO issues having multiple installations with that.
To the contrary, if fixes the issue of the phone becoming unresponsive with 8.0.x. Possibly 8.0.9 fixes that as well.
06-25-2008 11:07 AM
Hi, you have tu upgrate de CallManager Exprees version, a had Version 4.0(3), and i upgrated to 4.1, this resolve the problem.
thx
06-25-2008 11:49 AM
Here is the deal with that. I have a CME with 4.1 and a second one doing the same thing that currently has 4.2. Any other ideas what this could be?
06-25-2008 11:56 AM
Try to upgrate 4.2
06-25-2008 05:59 PM
Hi there,
I am having exactly the same issue as described in this thread.
When you go to transfer the call and no-one is there and you press end call then take the call off hold, you hear the ringing tone still.
IOS: c2800nm-advipservicesk9-mz.124-11.XW5.bin
Phone Load: load 7941 SCCP41.8-3-5S
Phones: 7941 and 7961
Just wondering if this may be an issue with the IOS, Phone load or a bug.
06-26-2008 05:36 AM
hi, witch version of CCM Express do you have?
06-26-2008 06:18 AM
According to the CME Matrix i am running:
12.4(11)XW5 4.2
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
06-26-2008 06:51 AM
this IOS resolve the problem
c2800nm-adventerprisek9-mz.124-15.T5.bin
06-26-2008 02:53 PM
Ok great. So was there a documented BUG for this issue that you found?
06-26-2008 03:00 PM
Everyone should run 12.4(15) T4 or higher, out of the sheer amount of Bug fixes and product compatability. just my 2 cents ;)
Chad
