Hall of Fame Super Gold
CCME- Changing rings on 7911/7941 ?
I can't find a document on how to do that.
I see that the phones are not requesting Ringlist.xml like the 7912 / 7940 predecessors.
Any help please ?
Hall of Fame Super Red
Re: CCME- Changing rings on 7911/7941 ?
Hi Paolo,
Customized Ring Tones
Cisco Unified IP Phones have two default ring types: Chirp1 and Chirp2. Cisco Unified CME also supports custom ring tones using pulse code modulation (PCM) files. An XML file called RingList.xml specifies the ring tone options available for the default ring on an IP phone registered to Cisco Unified CME. An XML file called DistinctiveRingList.xml specifies the ring tones available on each individual line appearance on an IP phone registered to Cisco Unified CME.
SUMMARY STEPS
1. Create a PCM file for each custom ring tone.
2. Edit the RingList.xml and DistinctiveRingList.xml files using an ASCII editor.
3. Copy the PCM and XML files to system Flash on the Cisco Unified CME router.
4. Use the tftp-server command to enable access to the files.
5. Reboot the IP phones.
Here are the details;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00806a8318.html#wp1155068
Hope this helps!
Rob
Hi Rob,
The problem is that as I mentioned, the phones are not making tftp request for these files like the 7912 and 7940 that I've configured before. Here is the output from debug tftp event when I reset a 7911 and 7941 in sequence.
.Jan 3 23:23:31.548 CET: %IPPHONE-6-UNREGISTER_NORMAL: ephone-7:SEP0019E7EE8E29 IP:192.168.4.4 Socket:1 DeviceType:Phone has unregistered normally.
.Jan 3 23:23:57.242 CET: TFTP: Looking for CTLSEP0019E7EE8E29.tlv
.Jan 3 23:23:57.318 CET: TFTP: Looking for SEP0019E7EE8E29.cnf.xml
.Jan 3 23:23:59.038 CET: TFTP: Opened system:/its/XMLDefault7911.cnf.xml, fd 1, size 1023 for process 69
.Jan 3 23:23:59.070 CET: TFTP: Finished system:/its/XMLDefault7911.cnf.xml, time 00:00:00 for process 69
.Jan 3 23:23:59.621 CET: %IPPHONE-6-REGISTER: ephone-7:SEP0019E7EE8E29 IP:192.168.4.4 Socket:1 DeviceType:Phone has registered.
.Jan 3 23:25:49.104 CET: %IPPHONE-6-UNREGISTER_NORMAL: ephone-8:SEP001A2F490C1D IP:192.168.4.11 Socket:6 DeviceType:Phone has unregistered normally.
.Jan 3 23:27:18.296 CET: TFTP: Looking for CTLSEP001A2F490C1D.tlv
.Jan 3 23:27:18.420 CET: TFTP: Looking for SEP001A2F490C1D.cnf.xml
.Jan 3 23:27:18.420 CET: TFTP: Opened system:/its/XMLDefault7941.cnf.xml, fd 1, size 1023 for process 69
.Jan 3 23:27:18.424 CET: TFTP: Finished system:/its/XMLDefault7941.cnf.xml, time 00:00:00 for process 69
.Jan 3 23:27:20.168 CET: %IPPHONE-6-REGISTER: ephone-8:SEP001A2F490C1D IP:192.168.4.5 Socket:3 DeviceType:Phone has registered.
I've solved my own problem. These newer phone are requesting the files only when accessing the settings menu and not at boot time. Alos, note that the xml files are now requested as all lowercase.
678
