Community Member
CCME COR ISR
I want to configure COR on a ISR router. I was hoping to block some phones to only allow them to dial internal phones only and possibly local calls.
I have been using http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
but this only blocks toll free, etc.
I dont want to create multiple dial peers this if possible.
If any has any suggestions that would be great.
Re: CCME COR ISR
hi friend,
may be you can apply this, for example:
dial-peer cor custom
name INTERNAL
name LOCAL
dial-peer corlist INTERNAL
member INTERNAL
dial-peer corlist LOCAL
member LOCAL
dial-peer corlist LOCAL_CALLS
member INTERNAL
member LOCAL
!-- for local calls
dial-peer voice 1 pots
destination-pattern [pattern]
!-- put this in "partition" LOCAL
corlist outgoing LOCAL
port [port]
ephone-dn 1 dualine
number 1000
!-- put this ephone in "partition" INTERNAL
corlist outgoing INTERNAL
!-- access to call ephones and local calls
corlist incoming LOCAL_CALLS
ephone-dn 2 dualine
number 1001
!-- access to only internal calls (ephones)
corlist incoming INTERNAL
-- adrián.
Community Member
Re: CCME COR ISR
hi Adrian,
Thanks for this, didnt get a chance to test this yes as have been busy on other elements thatnks for the reply as this is what I was think but wanted to check
121
