Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CCME dial-peer issue
Hello everyone,
I've stumbled across a very wierd problem on a CCME 4.1 system where there seems to be a dial-peer
that only shows up when I type 'show dial-peer voice summary' with the following details:
TAG ID= 20033
Destination-pattern= 8000...
Port= 50/0/90
The issue here is that the above dial peers doesn't exist in the configuration. At some point in the past
I created and then deleted it, and now I can't call any 800 numbers!
Any idea how I can delete this dial-peer ?
Cheers,
1 ACCEPTED SOLUTION
Re: CCME dial-peer issue
Hi friend,
Please check in your configuration the existence of ephone-dn 90 and look its destination-patterns. That seems to me that is a MWI on/off pattern for VoiceMail.
- adrián.
Hi friend,
- adrián.
Excuse me, I mean look for the number configured under ephone-dn 90, not destination-pattern.
Sorry.
- adrián.
Hi friend,
Dial-peer with tags similar to 20033 (and that can't be seen in the configuration) are dial-peers used to route calls thru virtual voice-ports (such as 50/0/90):
Take a look on this link, may be helpful:
http://www.ciscopress.com/articles/article.asp?p=401648
- adrián.
205
