CCME DID configuration
Dear all,
The CME router has VIC-2DID card which connect to CO. CO will provide 3 digit to the router.
How can I configure the voice port and dial-peer for the DID function.
Is the below command enough?
voice-port 1/0/0
signal did immediate
dial-peer voice 1 pots
called-number 8..
direct-inward-dial
port 1/0/0
Thanks.
1 REPLY
Bronze
Re: CCME DID configuration
You config looks fine for the most part. Try changing the following.
incoming called-number .
direct-inward-dial
port 1/0/0
108
