02-22-2012 03:11 PM - edited 03-16-2019 09:43 AM
Hi there,
I have 2 ccme Site A and Site B and both have cue integrated. Calls between them work fine.
The issue I have is when a call get diverted to cue due to the extension not answering or been busy.
So if from Site A I make a call to Site B and the call get diverted to Site B CUE the call gets cut off. After some debugging I found that this due to the fact that Site B ccme diverts the call to the CUE pilot number 7777 and that is a number that Site A ccme does not know how to route to.
If I add a dial-peer on Site A ccme with destination 7777 and ip address of the Site B ccme it works and the issue is resolved. My question is can this issue be resolved with the extra dial-peer on Site A as this solution dose not scale?
Alexis
Solved! Go to Solution.
02-22-2012 08:41 PM
Hi Alexis,
Add the following commands to disable redirection on the CME:
voice service voip
no supplementary-service h450.2
no supplementary-service h450.3
Insteat sending redirection info to the originating CME it will hairpin the call to CUE.
More info here:
Cheers,
Boris
02-22-2012 08:41 PM
Hi Alexis,
voice service voip
More info here:
Cheers,
Boris
02-23-2012 02:38 AM
Just what i was looking for.
Alexis
