CCME - Does the 7936 support login/after-hours PIN?
I have a CallManager Express 4.0.0(1) and am curious as to whether the 7936 can do the after-hours PIN login? I don't see it on the default softkey template.
Thanks.
Mike.
1 REPLY
Re: CCME - Does the 7936 support login/after-hours PIN?
Try the command load phone-type firmware-file .
To associate a type of Cisco Unified IP phone with a phone firmware file, use the load command in telephony-service configuration mode.
you can enable softkeys in ephone-template and associate the template to the ephone later.
150
