04-08-2012 07:22 PM - edited 03-16-2019 10:32 AM
CCME extension assigner was dialed today to swap out a broken phone, it normally works fine. The following is now occuring.
Dial the extension number, greeted with "Welcome CME EA, enter password". After dialing the first digit of the password (or any digit for that matter) you are cut off and says "please check with the system administrator for the correct password" and terminates the call.
I tried re-entering the param-ea password command, and got the following message? : "Warning: parameter ea-password has not been registered under EA namespace"
Debug and config is below:
Router#debug voip application script
voip application script debugging is on
Router#
Apr 9 02:14:35.523: //271//TCL :/tcl_PutsObjCmd: TCL: ***** >>> app-ccme-taps-2.0.0.0.tcl <<< *****
Apr 9 02:14:35.523: //271//TCL :/tcl_PutsObjCmd: TCL: ***** >>> Cisco CME Extension Assigner Application <<< ****
Apr 9 02:14:35.527: //271//TCL :/tcl_PutsObjCmd: >>> PROMPT: Enter password <<<
Router#
Apr 9 02:14:43.447: //271//TCL :/tcl_PutsObjCmd: >>> Collect Password Status = cd_006 <<<
Apr 9 02:14:43.447: //271//TCL :/tcl_PutsObjCmd: >>> PROMPT: Contact Sysadmin for password <<<
Router#
Apr 9 02:14:46.839: //271//TCL :/tcl_PutsObjCmd: **** >>> TCL: Closing Cisco CME Extension Assigner Application <<< ****
Router#
application
service EA flash:/EA/app-cme-ea-2.0.0.0.tcl
paramspace english language en
paramspace english index 0
paramspace english location flash:/EA/
paramspace english prefix en
param ea-password 1910
dial-peer voice 1910 voip
description CME Extension Assigner
service ea out-bound
destination-pattern 910
session target ipv4:192.167.101.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
telephony-service
extension-assigner tag-type provision-tag
04-09-2012 04:03 AM
The parameter warning message is normal for scripts.
Extension Assigned should not be very important on a working syste,. If you have to replace a phone, just configure the new MAC.
04-10-2012 01:45 AM
I opened the case with TAC and it was resolved within an hour. For anyone else that has this problem occur, I have copied and pasted the bug below:
EA password pattern matching fails with call-park system application
Symptoms
: Extension assigner (EA) application erroneously exits after the
first digit of the password is entered.
Conditions
: The symptom is observed when "call-park system application" is
configured under telephony-service.
Workaround: Remove "call-park system application".
Once the workaround was in-place, all issues with Extension Assigner stopped.
Nic.
