CCME - FXO - Cannot Dial Out
On a CCME router - my first to configure, when I try to dial out, I get a message from the telco that I "must first dial a 1 or 0 before calling this number" - this happens on local calls and long distance calls, even if I dial 9xxx-xxxx or 91(xxx)xxx-xxxx. which makes it seem like the 9 is being sent out possibly. I can't figure it out...
Router is 2811, VIC2-4FXO
Dial Peers:
dial-peer voice 1 pots
description ** FXO pots dial-peer **
destination-pattern 911
port 0/0/0
forward-digits all
dial-peer voice 2 pots
destination-pattern 9911
port 0/0/0
forward-digits 3
dial-peer voice 3 pots
corlist outgoing call-local
destination-pattern 9T
port 0/0/0
forward-digits all
dial-peer voice 4 pots
corlist outgoing call-domestic
destination-pattern 91T
port 0/0/0
dial-peer voice 5 pots
corlist outgoing call-international
destination-pattern 9011T
port 0/0/0
dial-peer voice 6 pots
corlist outgoing call-900
destination-pattern 91900.......
port 0/0/0
dial-peer voice 7 pots
corlist outgoing call-976
destination-pattern 91976.......
port 0/0/0
dial-peer voice 8 pots
port 0/0/1
forward-digits all
dial-peer voice 9 pots
port 0/0/1
forward-digits 3
dial-peer voice 10 pots
port 0/0/1
dial-peer voice 11 pots
port 0/0/1
dial-peer voice 12 pots
port 0/0/1
dial-peer voice 13 pots
port 0/0/1
dial-peer voice 14 pots
port 0/0/1
dial-peer voice 30 voip
description ** cue voicemail pilot number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 600
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 31 voip
description ** cue auto attendant number **
destination-pattern 601
codec g711ulaw
no vad
and just in case:
telephony-service
no auto-reg-ephone
load 7960-7940 P0030702T023
load 7912 CP7912080001SCCP051117A
max-ephones 36
max-dn 108
ip source-address 192.168.10.1 port 2000
calling-number initiator
service phone videoCapability 1
system message PEP ISD
time-zone 8
voicemail 600
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name cisco secret 5
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern 91T
secondary-dialtone 9
create cnf-files version-stamp 7960 Jun 05 2007 15:26:33
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CCME - FXO - Cannot Dial Out
rule 1 does nothing.
rule 2 strips 9 if first digit and can be rewritten more concisely as: /^9/ //
where do you have that and why ?
Rather check out that you have "forward-digits all" under DP 4 and I think you should not.
hello,
keep in mind that what is digits matched by destination-pattern are not set out, so for example when your DP 4 matches (you can see that with "term mon" and "debug voip dialpeer"), then telco complains because of the missing 1, so either you add it back with "prefix", or do "no digit-strip" and then a translation-rule... It may become complicated also considering that you are trying to do COR at the same.
having the same issue with local calls as well, so I'm not sure that is the problem. how can I see what digits are being outpulsed?
"term mon" and "debug vpm signal".
could this be causing a problem?
voice translation-rule 9
rule 1 /^911$/ /911/
rule 2 /^9\(.*\)/ /\1/
that was it, thanks!
Glad to know it worked, thanks for the nice rating and good luck!
May i know how it worked? im facing the same problem. What is the command u used in the dial-peer??
Manoj
Was incorrect "forward-digits" configuration.
338
