04-04-2012 01:09 AM - edited 03-16-2019 10:28 AM
I have C1861E-SRST router with c1861-advipservicesk9-mz.151-4.M2.bin and CCME 8.6.
PSTN is connected on FXO port.
Incomming call is forwarded to voice hunt-group (99) with 2 extensions on the list (91, 92). Both phones (SCCP) ring simultaneously, any of them can pick up the call. This works fine.
Caller-id is enabled on voice port.
The issue is, that caller-id displays only on the first extension from the hunt-group list (91). On the other phone "unknown number" appears on the display.
Here is the config:
voice hunt-group 9 parallel
list 91,92
pilot 99
voice-port 0/1/0
no battery-reversal
cptone SK
connection plar opx immediate 99
impedance complex2
caller-id enable
caller-id alerting ring 4
When I change the order of listed extensions to:
list 92,91
the caller-id displays on the 92 extension.
I need the caller-id to display on both phones. Is there a solution for this?
Thank you for the help.
Lubomir
Solved! Go to Solution.
04-04-2012 01:27 AM
Have you tried using a shared DN instead?
That is more tested and reliable solution.
04-04-2012 01:27 AM
04-04-2012 01:53 AM
Thank you, Paolo, it works this way.
Lubomir
04-04-2012 02:16 AM
Thanks for the nice rating and good luck!
