CCME FXO
Hi, I have a CCME in a 2801 Router, and 4 FXO ports, and I would like to do the following:
All calls received by the first FXO port are redirected to port two, three and four.
Can I do this?
(CCME v.7.0)
1 REPLY
Re: CCME FXO
Hi Ricardo,
Unless your FXO provider allows transfers, this isn't possible. I've seen some providers support transfers over their network, but they are few and far between.
When the call comes in on the FXO port, you will probably have the port automatically dial an auto-attendant or receptionist. There a number of different options you can implement at that level to handle call control instead.
What is it that you're trying to accomplish? There is most likely a better way to do this.
hth,
nick
104
