CCME / FXO
Hi, I?ve configured a CCME with two analog (FXO) connection against PSTN. I?ve two questions that I hope that somebody can answer me :
1.- The analog connection (FXO) is trought satellite connection. Do you know if this need a special configuration in a port? . The same config with "traditional" analog PSTN connection work propertly , but with satellite doesn?t work.Any idea ?
2.- The other question is : Could be possible priorize a extension to do a calls? I mean...We have three extensions and only two PSTN connections . One of this extensions is the most important , and I want that always can call...In case that the two others extensions are calling and the "most important extensions want to call" , is possible drop some of this normal extensions , in order that the "most important extensions" can call...I hope that you understand my question...
Many thanks for your help,
David S.
106
