Community Member
CCME GPickup
Dear All,
I am running CCME 4.2. I only want to dial one extension number to receive group pickup for a number to extensions.
Malik
1 ACCEPTED SOLUTION
Re: CCME GPickup
Hi Malik,
You will need to configure the pickup-group command under all your ephone-dns.
For example:
ephone-dn 1 dual-line
pickup-group 30
ephone-dn 2 dual-line
pickup-group 30
ephone-dn 3 dual-line
pickup-group 30
ephone-dn dual-line
pickup-group 30
Then you can pickup any call ringing at any phone from any other.
Hope it helps!
Best regards,
- Adrián.
Re: CCME GPickup
Hi Malik,
Here is the link to CME PickUp feature:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1092675
Hope it helps you!.
Best regards,
- Adrián.
Community Member
Re: CCME GPickup
thanks for your response...i will configure it and if there is any issue i will let you know...
Community Member
Re: CCME GPickup
Can anybody tell me how i can configure
"Call Pickup, a Single Group for All Cisco CME Phones"
Malik.
Re: CCME GPickup
Hi Malik,
For example:
pickup-group 30
pickup-group 30
pickup-group 30
ephone-dn dual-line
pickup-group 30
Hope it helps!
Best regards,
- Adrián.
Community Member
Re: CCME GPickup
GREAT!!!!Thanks Mr. Adria. Really appreciate your support....
Malik...
Re: CCME GPickup
Hey Malik,
You're welcome! :)
Glad to help a bit!
- Adrián.
219
